Control Freak checks are automatically approved without any checks
Purple Cyber
September 18, 2025
I am using a premium Bitbucket Cloud membership. I have set up control freak checks to merge into master. For e.g. one check is to validate the commit message starts with jira reference. In the branch restriction for master I have checked the option "No unresolved pull request tasks" and also "Prevent a merge with unresolved merge checks". Now I made a commit with a test message without any jira reference. I see the tasks opened for each checks. But the bitbucket immediately resolves all the tasks without any checks. None of the conditions are met but the tasks are still resolved. Can someone please help why this might be happening?
Robert Chilvers _bit-booster_com_
September 20, 2025
Hi @Purple Cyber
Please reach out to me at robert@bit-booster.com or support@bit-booster.com and I will help you resolve the issue with our plugin.
Thanks for using Control Freak, and please reach out.
Thanks Robert
Aron Gombas _Midori_
You may also want to test the Better Commit Policy Connector app to implement this check.
It can test if the commit message starts with a work item reference and even if the work item is valid and matches a configurable JQL query. See the config guide.
You can make the check mandatory, so it will disallow merging a PR if any commit message in that misses the work item link. It will integrate to the pull request screen like this:
(Discl. this app is developed and supported by our team.)
Saxea _Flowie_
Hi @Purple Cyber ,
I'd suggest reaching out to the vendor support channel directly. In case of control freak they list the contact information here
Alternatively, you might also want to check out a Bitbucket cloud app we provide, that can validate commits which you might find useful too.
