Cron expression in bitbucket-pipeline.yml?
Bruno Romagnoli
February 20, 2023
I want to schedule a pipeline using a cron expression but i don't know how to add that value to my bitbucket-pipeline.yml in order to see it when using the schedule function in bitbucket.
How do i add it in the bitbucket-pipeline file?
Theodora Boudale
February 21, 2023
Hi Bruno!
Schedules are not configured in the bitbucket-pipeline.yml file. If you open the Pipelines page of the repo, you will see an option Schedules at the top right corner.:
You can select that option in order to create a schedule.
Another option is to use our API to create a schedule and you can pass the cron expression as an argument:
An example API call is the following:
curl -X POST -u Bitbucket_Username:App_Password 'https://api.bitbucket.org/2.0/repositories/workspace-id/repo-slug/pipelines_config/schedules/' -H 'Content-Type: application/json' -H 'Accept: application/json' -d '{
"type": "pipeline_schedule",
"target": {
"ref_type": "branch",
"type": "pipeline_ref_target",
"ref_name": "master",
"selector": {
"type": "custom",
"pattern": "master"
"cron_pattern": "0 0 0 1 * ? *"
Please feel free to let me know if you have any questions.
Theodora
Bruno Romagnoli
February 22, 2023
This will do.
Thank you very much.
Like Theodora Boudale likes this
