Hi team,
we are using bitbucket pipeline for ci/cd and i wanted to integrate DAF testing frame work to build pipeline so i waned to know steps to integrate automation testing frame in to my bitbucket pipeline.
Hi @jaya_prakash_,
I'm not familiar with this testing framework; I just wanted to let you know that Pipelines builds run in Docker containers.
If there is a way to run these tests in a Docker container, then it may be possible to do so in Bitbucket Pipelines as well by configuring the appropriate image in your bitbucket-pipelines.yml file and including the commands for testing in the script of a step. You can check the following doc on how to configure the bitbucket-pipelines.yml file:
I would suggest checking with the developers/support team of this framework if it is possible to run the tests in a Docker container, and if they provide a Docker container with all tools needed for these tests, which you could use in Pipelines.
Theodora
