Delete a script (source) from a branch in BitBucket
Francesco Ciriachi
August 16, 2019
Good morning and happy Friday everyone. I've a question about BitBucket. I'm trying to delete a source from a shared branch, however after a few attempts and google searches, I couldn't find a solution for what I thought was relatively straightforward (could be I'm missing something very obvious like a drop down button or similar). Is anyone able to help? Thanks in advance
Daniil Penkin
August 20, 2019
Hello @Francesco Ciriachi,
What do you exactly mean by delete a source from a shared branch?
If this means deleting one (or few) file from that branch, you can do that in UI, single file at a time (make sure you selected the right branch in the dropdown at the top):
Note that every time you delete a file this way, a commit will be created on the branch in questions, that said the file you deleted will remain in the history of that branch.
If you need to remove more than one file, you might want to consider doing it in a single commit in your local copy of the repository, then pushing that commit to Bitbucket.
If you need to remove the file completely, i.e. not leave it in the history of your repository, you'll have to use history rewrite (assuming your repository is a Git one). This can only be done in your local copy of the repository, there're no tools for this in Bitbucket UI.
Hope this helps. Let me know if you have any questions.
Daniil
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
