Is it possible, with BitBucket Pipelines, to deploy code from a specific commit onwards?
For example when using an FTP pipeline I might want to deploy code only from the last 2 commits as the previous commits may already be deployed.
Hi @Steve Perry ,
if I understand you right, you want to deploy just new changes.
In your case, you can use the pipe rsync-deploy.
More available pipes you can discover on the Bitbucket Pipes page.
Alex
Hi Alex
Thanks for the response. Whilst I think that might work, I'm looking for a way to specify an actual commit hash to start from. For example specifying an actual commit to start from in the config file.
rsync-deploy will probably do the job behind the scenes so it's worth me looking at but I'd like manual control if pos.
Steve
