If I remember correctly, the caching of this example worked before:
bitbucket-pipelines.yml
image: atlassian/default-image:4 pipelines: custom: test-build-docker-image: - step: name: Build Docker image script: - export DOCKER_BUILDKIT=0 - docker load -i docker-cache/* || echo "No cache" - docker build . - mkdir -p docker-cache && docker save $(docker images -aq) -o docker-cache/cache.tar caches: - my-docker-cache services: - docker definitions: services: docker: memory: 7168 caches: my-docker-cache: key: files: - Dockerfile path: docker-cache options: size: 2x
Dockerfile
FROM busybox:1.36.1 RUN echo "first" RUN echo "second" RUN echo "third"
+ docker load -i docker-cache/* || echo "No cache" open docker-cache/*: no such file or directory No cache + docker build . Sending build context to Docker daemon 137.8MB Step 1/4 : FROM busybox:1.36.1 1.36.1: Pulling from library/busybox 9ad63333ebc9: Pulling fs layer 9ad63333ebc9: Verifying Checksum 9ad63333ebc9: Pull complete Digest: sha256:6d9ac9237a84afe1516540f40a0fafdc86859b2141954b4d643af7066d598b74 Status: Downloaded newer image for busybox:1.36.1 ---> 3f57d9401f8d Step 2/4 : RUN echo "first" ---> Running in 9f5db0912aa0 first ---> Removed intermediate container 9f5db0912aa0 ---> aef0afc1d25e Step 3/4 : RUN echo "second" ---> Running in 6673f56d9742 second ---> Removed intermediate container 6673f56d9742 ---> efd280830d9e Step 4/4 : RUN echo "third" ---> Running in cbb666b81938 third ---> Removed intermediate container cbb666b81938 ---> 7d5f23f53603 Successfully built 7d5f23f53603 + mkdir -p docker-cache && docker save $(docker images -aq) -o docker-cache/cache.tar Build teardown Assembling contents of new cache 'my-docker-cache' Cache "my-docker-cache: docker-cache": Cache key 45d889b080d15a21c02bbb55a24c59ded2823339d2a3e51d237e8119a7a2fd79 Cache "my-docker-cache: docker-cache": Compressing Cache "my-docker-cache: docker-cache": Compressed in 0 seconds Cache "my-docker-cache: docker-cache": Uploading 2.1 MiB Cache "my-docker-cache: docker-cache": Uploaded in 1 seconds Searching for test report files in directories named [test-results, failsafe-reports, test-reports, TestResults, surefire-reports] down to a depth of 4 Finished scanning for test reports. Found 0 test report files. Merged test suites, total number tests is 0, with 0 failures and 0 errors.
Build Setup ... Cache "my-docker-cache: docker-cache": Cache key 45d889b080d15a21c02bbb55a24c59ded2823339d2a3e51d237e8119a7a2fd79 Cache "my-docker-cache: docker-cache": Downloading Cache "my-docker-cache: docker-cache": Downloaded 2.1 MiB in 0 seconds Cache "my-docker-cache: docker-cache": Extracting Cache "my-docker-cache: docker-cache": Extracted in 0 seconds ... + docker load -i docker-cache/* || echo "No cache" Loaded image ID: sha256:7d5f23f53603a6c0cfc8f66a28a2abf0da920cd669c6bd60ed67f0c3a963c99d Loaded image ID: sha256:aef0afc1d25edf254e23a06940b2ff43c022fc8e0cc7d010d95d938a9b10869f Loaded image ID: sha256:efd280830d9e615ef6d0ec7353da56151e5a29c02f71c81e640144a986483cc3 Loaded image ID: sha256:3f57d9401f8d42f986df300f0c69192fc41da28ccc8d797829467780db3dd741 + docker build . Sending build context to Docker daemon 142.3MB Step 1/4 : FROM busybox:1.36.1 1.36.1: Pulling from library/busybox Digest: sha256:6d9ac9237a84afe1516540f40a0fafdc86859b2141954b4d643af7066d598b74 Status: Downloaded newer image for busybox:1.36.1 ---> 3f57d9401f8d Step 2/4 : RUN echo "first" ---> Running in 455f29e76cb0 first ---> Removed intermediate container 455f29e76cb0 ---> 2e82ca3f66ee Step 3/4 : RUN echo "second" ---> Running in 449de7072c2a second ---> Removed intermediate container 449de7072c2a ---> 694a3cee4ae5 Step 4/4 : RUN echo "third" ---> Running in b21aa5672cb9 third ---> Removed intermediate container b21aa5672cb9 ---> d9162b45ec07 Successfully built d9162b45ec07
Why are the layers in the second run not cached?
Facing the same issue here.
It seems to be related to version 25.0.2 of Docker, which was updated on February 2nd, according to the report at the following link: Infrastructure Changes in Bitbucket Pipelines.
It appears to have been resolved in version 25.0.3. Here's the link to the release notes: Docker Engine Release Notes - 25.0.3.
Support told me that version 25.0.3 does not fix the issue. They downgraded the Docker version of my workspace till a fix for a newer Docker version is available. Caching works again with the downgraded version.
Hello @maiermic and thank you for reaching out to Community!
I will raise an internal ticket to further investigate the pipeline issue you are facing. You should be receiving an email with the ticket link soon. In case you don't receive it, please let me know so I can share the ticket here in the community (the ticket is only visible to you and Atlassian staff).
Thank you, @maiermic !
Patrik S
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
