In my pipeline I am using service docker. I am trying to Copy a file if it exists, but the engine version , Copy needs at least one file to exist otherwise it fails. I have tried with global expressions, resource/*.txt, resource/*.tx[t] resource/*.?xt. it doesn't work but in docker desktop it works normal to date. but in my pipeline the same instruction returns this error no error is returned: no source files were specified
Hi @rsalazari and welcome to the community.
If the resource/ directory contains only text files (when it's not empty) and you want to copy all of them, you can try the following command instead
COPY resource/ /path-to-destination-dir/
I have tested this in Pipelines and the command doesn't fail if the resource/ directory is empty.
If the resource/ directory may contain files other than .txt ones that you don't want to copy, I would suggest copying the txt files first in a separate directory before you build the Docker image, so you can then use a COPY command similar to what I have shared.
You mentioned that locally you haven't had any issues. Could you perhaps let me know the output of docker version on this machine, and the OS + version of the machine?
Theodora
Thank you very much for the answer in that in my resources folder there are more than one sensitive file and I do not want to copy all of them, only one specific one, of course, as long as the file exists. This is because the idea is to make a dockerfile Generic - my projects contain the same instructions with the differential that some do not have that file and also not copy
Hi @rsalazari,
Thank you for your reply and the additional details about your use case. Does my suggestion work for you or are you still having any issues?
Theodora
It works, but since I have files that should not be copied for security reasons, copying them is not feasible yet. I would think it would be great if the COPY instruction would not fail even if it does not find a resource, it would just throw a waring.
I understand what you are saying; this is the only workaround I can think of at the moment, which would work if the files you want to copy are saved in a separate folder from the ones you don't want to copy.
With Docker Desktop this indeed does not fail. However, I tried installing the latest version of Docker Engine on a Linux machine, and the copy fails as well (with resource/*.txt and resource/*) if there are no files in the directory. It doesn't look like the issue is specific to Pipelines and the version of Docker in Pipelines; it looks like this is something that works with Docker Desktop but not with Docker Engine.
Theodora
