The examples in AWS Code Deploy pipe mentions that 'deploy' command will deploy the previously uploaded application zip from S3. Does this mean one has to write two scripts for the same pipe atlassian/aws-code-deploy:1.0.0 - first upload and then deploy ?
Or if one uses just the deploy command then will the pipe upload the zip to S3 by itself before deploying?
@Kush Saraiya exactly, you will firstly need to use example for upload, then one for deploy command usage. It is done to separate this functionality, because it can be too different and with different arguments.
Cheers, Galyna
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
