I am evaluating Dynamic Pipelines for our workflows, and they are pretty smooth!
I want to know if you have best practices you can share when it comes to Custom Pipelines.
Can I define Custom Pipelines in via the provider?
Or would I add empty custom pipelines and update their contents?
Hi @Georg Duemlein !
I'm not quite sure I know what you're referring to here. Custom pipelines are manually triggered, are defined using the custom tag and require you to manually enter these in your YML config - please see our documentation below:
Please let me know if I've misunderstood your query.
Cheers!
- Ben (Bitbucket Cloud Support)
Thanks, Ben!
In the meantime I did more research and learned that indeed the Dynamic Pipeline Provider can add and modify Custom Pipelines.
So I was able to add a Custom Pipeline in the provider that shows in the list of available pipelines in the UI. I guess that is what I was after.
