After following the steps in the key changes document: https://bitbucket.org/blog/ssh-host-key-changes
We can still get this error:
Warning: the ECDSA host key for 'bitbucket.org' differs from the key for the IP address '2406:da00:ff00::22c5:2ef4'
Offending key for IP in /srv/httpd/*host*/.ssh/known_hosts:6
Matching host key in /srv/httpd/*host*/.ssh/known_hosts:11
Removing the offending lines solves this for a short time. But then it returns again.
This doesn't happen if we force our git commands to use ipv4, it only happens for traffic over ipv6.
What we want to confirm is the following:
Hi @collinmaessen,
The reason that you see this error is that there are entries in your known_hosts using our IPs instead of the domain bitbucket.org.
You can remove them by running
ssh-keygen -R bitbucket.org && sed -i.old -e '/AAAAB3NzaC1yc2EAAAABIwAAAQEAubiN81eDcafrgMeLzaFPsw2kNvEcqTKl/d' /srv/httpd/*host*/.ssh/known_hosts && curl https://bitbucket.org/site/ssh >> /srv/httpd/*host*/.ssh/known_hosts
You could also delete and recreate the known_hosts file and then copy and paste into the new file the entries from https://bitbucket.org/site/ssh. However, if you connect to other hosts via SSH as well from this machine, and you have their host keys in the known_hosts, then deleting the known_hosts file will affect the SSH connections to these hosts as well. The next time you connect to such a host via SSH you will see a prompt with the host's fingerprint, asking you if you trust the host, so that its host key gets added to known_hosts.
Theodora
