Export JIRA issues to Bitbucket
fernandomm September 14, 2014
Is it possible export JIRA issues to Bitbucket? I'm trying to find this information but I can only find info about exporting Bitbucket issues to JIRA.
If it's possible, is there a way to keep the reference between commits in the repository and issues?
Meril Arenas
June 3, 2015
Hi Jesse,
Is it still not possible now? I would like to create an issue from JIRA then ideally the issue would also automatically appear in the linked bitbucket repository
Meril
jyo
September 23, 2014
Hi Fernando,
While it is possible to import Bitbucket issues into JIRA, this doesn't go the other way around.
Jesse
