FTP-Deploy with SSL
Marcel Izgin
May 19, 2020
How can you use the ftp-deploy pipe with SSL?
Oleksandr Kyrdan
May 19, 2020
Hi @Marcel Izgin ,
Thank you for your question!
The best choice for your case might be sftp-deploy pipe.
You can follow steps from the deploy-using-scp guide but use sftp-deploy pipe instead.
Alex
Frans Irgolitsch
May 19, 2020 edited
Hi Alex,
What I interpret from his question is that he means ftps, not sftp. The sftp pipeline isn't a solution for that.
I am myself wondering if this is possible as I'm currently getting an error that SSL is required. From what I see in the pipeline source, SSL is forced off in the pipeline, making ftps impossible. I was wondering what the reasoning behind this was.
Halyna Berezovska
May 20, 2020 edited
@Frans Irgolitsch you are right, this solution with ftps needs to be investigated and tested. However right now it is also good idea for custom pipe. You can explore how easily you can write a new one Creating a custom pipe . Contact us in the case of questions!
Steven Lindelauff
July 29, 2020
Any update on this? Maybe have the user select ssl as an option instead of forcing it off?
Halyna Berezovska
July 31, 2020 edited
@Steven Lindelauff right now we are not really to support this. The reason is that we recommend users to use sftp instead of ftps since ftps looks like a bit legacy. You can find pros and cons here https://www.nsoftware.com/kb/articles/legacy/sbb/ftps-vs-sftp.rst .
We actually recommend to adapt your pipeline to use sftp-deploy pipe instead of ftp-deploy.
BUT if you're not ok with this or it fails it would be nice to provide us with more details of your case.
At any time you can always create a custom pipe that comply your needs.
Looking forward to hearing back from you, thanks
ob April 26, 2021 edited
We used the following custom solution, instead of creating a custom pipe:
  • Use of the bitbucketpipelines/ftp-deploy Docker image in the build step.
  • Execute the lftp command manually with the needed ssl options/commands
Example bitbucket-pipelines.yml file:
- step: deployment-step
image: bitbucketpipelines/ftp-deploy:0.3.6
script:
- lftp -u "$FTP_USER,$FTP_PASSWORD" -e "set ftp:ssl-force true; set ftp:ssl-allow true; set ftp:ssl-protect-data true; mirror -vvv --exclude=some_exclude_file -R $BITBUCKET_CLONE_DIR /REMOTE_PATH;quit" $FTP_HOST
- echo "Deployment finished"
This worked for us so far.
atlassian, state of devex 2025, developer experience, devex report, developer productivity, ai in software development, engineering challenges, team collaboration, internal developer platform, time management, developer survey, space framework
Atlassian State of Developer Experience Report 2025
AI is reshaping the dev experience, with faster builds but adding more friction. See what 3,500 developers and managers say about productivity, tools, and team alignment in Atlassian’s State of Developer Experience report 2025.
Explore the report
