Facing issue with branch creation
manish_taazaa May 2, 2024
Hello team,
I am currently facing an issue on Bitbucket that previously, I was able to create a branch with the same name as the source branch prefix . For example, if the source branch was named "test", I could easily create a branch named "test/sonar". However, recently I have been facing issue in doing this. Whenever I try to create a branch following the same pattern, Bitbucket doesn't allow it.
Patrik S
May 3, 2024
Hello @manish_taazaa ,
thank you for reaching out to the Community!
It may be the case that there's a branch restriction preventing you from creating a branch with a given pattern in that repository.
If you have any branch restriction set in the repository that matches the name/pattern of the branch you are trying to create, verify if you have been granted write access to that restriction.
The creation of a branch is considered a write operation, so for branch names/patterns protected by a branch restriction, you need to have write access configured in that branch.
Hope that helps! Let me know in case you have any questions.
Thank you, @manish_taazaa !
Patrik S
manish_taazaa May 7, 2024
  • Thank you!!!!!
Like Patrik S likes this
Patrik S
May 7, 2024
Happy to have been of some help!
Feel free to reach out to Community if you ever need assistance with Bitbucket :)
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
