I want to create an API token in Sourcetree that only allows read and write access to the repository.
When I try to create an API token with the following scopes and attempt authentication, it fails.
“Your credentials lack one or more required priviledge scopes.”
write:repository:bitbucket
read:repository:bitbucket
When I select all available scopes and create an API token, authentication fails with the following message:
“Invalid URI: Could not resolve hostname.”
What scope settings should I select to authenticate successfully?
A hostname resolution error occurred when selecting the scope to read user information.
read:user:bitbucket
