FileNotFoundError in bitbucket pipeline
sukhija0004
June 1, 2021
Theodora Boudale
June 2, 2021
Hi @sukhija0004 ,
The second yml file that you posted in your reply seems to generate an 'application.tar.gz' file. However, this artifact cannot be used by the third step, because the steps are parallel.
Parallel steps cannot use artifacts produced by steps in the same parallel set. Since the steps are not running sequentially, the step using the artifact may start running before the artifact is generated by the second step.
I would suggest making the third step ('Deploy Code') a non-parallel step. Then, it should be able to use the artifact generated by 'Create artifact' step.
If you have any questions, please feel free to let me know.
Theodora
sukhija0004
June 1, 2021
