I'm encountering a build failure while running the flutter build apk
command as part of my Bitbucket pipeline. The build process is failing due to issues with the Gradle shrinker, resulting in the following error message:
Build Failed in 12m 32s
Deprecated Gradle features were used in this build, making it incompatible with Gradle 9.0. You can use '--warning-mode all' to show individual deprecation warnings and determine if they come from your own scripts or plugins. See https://docs.gradle.org/8.0/userguide/command_line_interface.html#sec:command_line_warnings 882 actionable tasks: 881 executed, 1 up-to-date Some file system contents retained in the virtual file system are on file systems that Gradle doesn't support watching. The relevant state was discarded to ensure changes to these locations are properly detected. You can override this by explicitly enabling file system watching.
Running Gradle task 'assembleRelease'... (completed in 753.0s)
Flutter Fix
[!] The shrinker may have failed to optimize the Java bytecode. To disable the shrinker, pass the `--no-shrink` flag to this command. To learn more, see: https://developer.android.com/studio/build/shrink-code
Here are the last few lines of the log:
"flutter apk" took 755,487ms. Gradle task assembleRelease failed with exit code 1. #0 throwToolExit (package:flutter_tools/src/base/common.dart:10:3) #1 AndroidGradleBuilder.buildGradleApp (package:flutter_tools/src/android/gradle.dart:544:7) #2 AndroidGradleBuilder.buildApk (package:flutter_tools/src/android/gradle.dart:224:5) #3 BuildApkCommand.runCommand (package:flutter_tools/src/commands/build_apk.dart:141:5) #4 FlutterCommand.run. (package:flutter_tools/src/runner/flutter_command.dart:1408:27) #5 AppContext.run. (package:flutter_tools/src/base/context.dart:153:19) #6 CommandRunner.runCommand (package:args/command_runner.dart:212:13) #7 FlutterCommandRunner.runCommand. (package:flutter_tools/src/runner/flutter_command_runner.dart:420:9)
Build Script
- export PATH="$PATH:/sdks/flutter/bin"
- flutter clean
- GIT_SSH_COMMAND="ssh -i ~/.ssh/id_rsa" flutter pub get
- flutter build apk --verbose || { echo "Build failed"; exit 1; }
Solution This issue refers into proguard-rules if used inside the app in my case update this file and its work fine
You find missing's scripts inside mappings directories
Hi Mohammad!
I'm not familiar with flutter, so I can't answer any questions related to that. However, I can give you some context on the environment that Pipelines builds run so you can debug this.
If you run Pipelines builds on Atlassian's infrastructure or with a self-hosted Linux Docker runner, these builds run in Docker containers based on the Docker image you have specified in your bitbucket-pipelines.yml file.
If you have Docker installed on your computer, you can debug a Pipelines build locally with Docker following this guide:
If you follow the steps of the guide, you'll have a clone of the repo at the same commit as the failed build and also use the same Docker image.
You can then debug the issue locally without consuming Pipelines minutes and run additional commands to debug it.
You could also try different Docker images if the one you are using now does not have the version of the tools you need. We support public and private Docker images including those hosted on Docker Hub, AWS, GCP, Azure and self-hosted registries accessible on the internet:
If you run Pipelines builds with a self-hosted Linux Shell, MacOS, or Windows runner, these builds run directly on the host machine using Bash (Linux Shell and MacOS runners) and PowerShell (Windows runners). You can debug these builds outside the runner using Bash or PowerShell respectively.
Please feel free to reach out if you have any questions!
Theodora
You are very welcome! Thank you also for posting the solution!
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
