×Implementing a shell script and calling the .sh file from bitbucket pipeline.yml
Currently facing an issue to retrieve the files inside a folder in the source code.
need to execute the class files as a post deployment step.
I am using For loop:
for f in /deploy/scripts/* .cls do
echo “$f”
done
the output should be the the class filenames inside scripts folder but it simply returns the string
any help or advice how to resolve this?
thanks
That isn't the proper syntax, you need to run:
for f in $(ls /deploy/scripts/*.cls); do echo "$f"; done;
