Get build-wrapper error after running bitbucket pipeline
fatma_elbehi January 31, 2022
Hi Team,
I am working on maven project and trying to integrate sonarCloud I received a failed pipeline with the following error
I need you help please asap!
Best,
Fatma
Norbert Csupka
February 2, 2022
Hi Fatma,
Thank you for contacting Atlassian Community, my name is Norbert and I'm a Bitbucket Cloud Support Engineer, it's nice to meet with you!
I would like to inform you that unfortunately SonarCloud is unsupported on our side as it wasn't developed by Atlassian and we're not familiar with this product. In case you wish to receive support from this application, we would like to suggest you to contact SonarQube for support.
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
