Git Push Timeout
john
October 9, 2024
I get the following error when trying to git push to my bitbucket repo. The compressing objects and writing happens instantly then it hangs for 10minutes and times out. I pushed a smaller commit on this new branch 2 hours ago so nothing else has changed except this new (bigger) commit.
The error:
git.exe push --progress "origin" feature/PLNK-178-eft-emails2:feature/PLNK-178-eft-emails2 Enumerating objects: 156, done. Counting objects: 100% (156/156), done. Delta compression using up to 12 threads Compressing objects: 100% (86/86), done. Writing objects: 100% (88/88), 92.88 KiB | 4.42 MiB/s, done. Total 88 (delta 73), reused 0 (delta 0), pack-reused 0 error: RPC failed; HTTP 503 curl 22 The requested URL returned error: 503 send-pack: unexpected disconnect while reading sideband packet fatal: the remote end hung up unexpectedly Everything up-to-date
I've tried:
- git config --global http.postBuffer 524288000
- re-clone
- restart
- new branch
john
October 10, 2024
I tried this again:
git config set post buffer
git config core.compression 0
git push
Then it asked to log in (might have removed my windows credential manager key in testing). Anyway it seems to work now.
