Git - proxy problem
Armand Gutierrez January 15, 2013
Hi, I am trying to upload my first repository under Git, but I am getting an error.
So, having the first files to "push" to the repository, and when I launch the command :
$ git push -u origin master
Password:
Password:
XML error: not well-formed (invalid token)
error: no DAV locking support on http://mandorman@bitbucket.org/mandorman/ngs-scripts.git/
fatal:
git-http-push failed
So for two times it question me for enter a password (according to the tutorial is supposed to be the same password than I use to enter to bitbucket account) ... and it fails.
As I am running under a proxy I think that maybe the problem could be arround here, any ideas?
aMarcus
January 23, 2013
Looking on Stack Overflow, someone mentioned that this could be an issue with the version of Git you are running. Check to be sure you are running the latest version of git.
Armand Gutierrez January 22, 2013
How it works git? if "git remote -v" and with fetch and push is something arround https://XXX@bitbucket.org/scripts.g
it means that git it works around the port of "https" no? I changed into "http" just to check but also it does not work.
No ideas?
Matt
January 16, 2013
Have you tried to push with ssh?
Please run this and paste output:
git remote -v
Armand Gutierrez January 16, 2013
Dear Matt,
Ok, this is the output:
armand2@armandu:scripts_armand$ git remote -v
origin https://mandorman@bitbucket.org/mandorman/ngs-scripts.git (fetch)
origin https://mandorman@bitbucket.org/mandorman/ngs-scripts.git (push)
Thanks for your help!,
Armand Gutierrez January 21, 2013
Any Ideas?
This dark problems remind me something about proxy ...
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
