Hard limit reached. What to do?
dave carney
July 1, 2015
Zoinks! My repo got out of the backyard and ran wild through the neighborhood. Now its' breached the 2GB limit. I've read over the documentation on how to split a repo, but can't follow the steps to do so because it is already locked. Is there anything I can do to get my repo back in working order?
jyo
July 1, 2015
Hi Dave,
Be sure to e-mail Bitbucket support (support@bitbucket.org) or use the help links within Bitbucket to access our support portal when this happens – we can remove the limit to allow you to push again. We recommend you take a look at the following article: https://confluence.atlassian.com/display/BITBUCKET/Maintaining+a+Git+Repository
There are a few options, however, I recommend using http://rtyley.github.io/bfg-repo-cleaner/ as it's the easiest and most straight forward. It's always a good idea to keep a cloned copy as a backup in case something bad happens. Once you've made your changes and removed the files, simply tell us and we can perform the necessary garbage collection on our end.
Jesse
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
