Having trouble with pipe cloudfront invalidation
Duy Nguyen December 25, 2024
Hi folks,
I'm using this for cloudfront invalidation but encountering this error. Does anyone have any ideas?
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: exec: "python3": executable file not found in $PATH: unknown.
91
https://bitbucket.org/atlassian/aws-cloudfront-invalidate/src/master/
Igor Stoyanov
December 27, 2024
Hi @Duy Nguyen . Thanks for your question.
Please, provide more details:
  • your bitbucket-pipelines.yml configuration file (do not expose any secrets)
  • your detailed log output from pipelines
Regards, Igor
Duy Nguyen December 29, 2024
Hi Igor,
Here's what you asked for
Pipeline config file. Please don't mind the validity of the file, I just remove the sensitive part.
image: node:20
definitions:
steps:
- step: &build
- step: &deploy
- step: &cloudfront-invalidations
name: Cloudfront invalidations
runs-on:
- self.hosted
- linux
oidc: true
script:
- pipe: atlassian/aws-cloudfront-invalidate:0.10.1
variables:
AWS_DEFAULT_REGION: $AWS_DEFAULT_REGION
AWS_OIDC_ROLE_ARN: $AWS_ARN
DISTRIBUTION_ID: $DISTRIBUTION_ID
PATH: '/*'
pipelines:
branches:
main:
- step: *build
- step: *deploy
- step: *cloudfront-invalidations
I can't send the entire log since the forum is giving me an error regarding html.
The error I shared on the post was the only error. The rest of the logs was about setting up docker container with some environment variables and docker pull logs.
Igor Stoyanov
December 29, 2024
Hi @Duy Nguyen .
From what i see, you use wrong configuration:
variables:
PATH: '/*'
You use  PATH, but pipe expect PATHS
script:
    variables:
      DISTRIBUTION_ID: '123xyz'
      PATHS: '/index.html /home.html'
Regards, Igor
Like • Duy Nguyen likes this
Duy Nguyen December 30, 2024
Thanks for pointing that out Igor, silly me.
Like • Igor Stoyanov likes this
atlassian, bitbucket, ci/cd workflows, scale ci cd, bitbucket webinar, devops pipeline, continuous integration, continuous delivery, atlassian learning, software automation, developer tools, build and deploy, pipeline optimization, atlassian community
Scale CI/CD workflows faster with Bitbucket Pipelines 🪣
Join this webinar on June 25/26th to learn how to build secure CI/CD workflows using Bitbucket Pipelines and get tips from our own engineers on how to speed up builds and operate at scale.
Register today
