Given the following pipeline configuration, the Pipeline Validator claims it is good but the pipeline gives an error:
There is an error in your bitbucket-pipelines.yml at [pipelines > default > 3 > parallel > 0]. The step section is empty or null.
Thanks your answer.
My pipeline:
image: gradle:8.10.1-jdk21
definitions:
steps:
- step: &deploy-step-template
name: Deploy to Environment
trigger: manual
script:
- apt-get update && apt-get install -y jq
- export MAJOR=$(jq -r '.major' version.json)
- export MINOR=$(jq -r '.minor' version.json)
- export PATCH=$(jq -r '.patch' version.json)
- export DATE=$(date +%Y%m%d)
- export VERSION="$MAJOR.$MINOR.$PATCH-$DATE-$BITBUCKET_BUILD_NUMBER"
- apt-get update && apt-get install -y sed
- sed -i "s|{{environment}}|$ENVIRONMENT_NAMESPACE|g" k8s/deployment.yaml
- sed -i "s|{{version}}|$VERSION|g" k8s/deployment.yaml
- pipe: atlassian/kubectl-run:3.11.0
variables:
KUBE_CONFIG: $KUBE_CONFIG
KUBECTL_COMMAND: 'apply'
RESOURCE_PATH: 'k8s/deployment.yaml'
- sed -i "s|{{environment}}|$ENVIRONMENT_NAMESPACE|g" k8s/service.yaml
variables:
RESOURCE_PATH: 'k8s/service.yaml'
services:
postgres:
image: postgres:latest
environment:
POSTGRES_DB: torep_db
POSTGRES_USER: torepservice
POSTGRES_PASSWORD: admin123
pipelines:
default:
- step:
name: Build and Test
caches:
- gradle
services:
- postgres
script:
- gradle build
artifacts:
- build/libs/**/*.jar
after-script:
- pipe: atlassian/checkstyle-report:0.3.0
- step:
script:
# Run a security scan for sensitive data.
# See more security tools at https://bitbucket.org/product/features/pipelines/integrations?&category=security
- pipe: atlassian/git-secrets-scan:0.5.1
- step:
name: Generate and push Docker image
trigger: manual
services:
- docker
caches:
- docker
script:
- echo $DOCKER_HUB_TOKEN | docker login -u $DOCKER_HUB_USERNAME --password-stdin
- docker build -t bsce/2repservice:$VERSION .
- docker push xxx/xxxservice:$VERSION
- parallel:
- steps:
- step:
<<: *deploy-step-template
name: Deploy to Test1
deployment: Test1
- step:
name: Deploy to Test2
deployment: Test2
- step:
name: Deploy to RC1
deployment: RC1
- step:
name: Deploy to RC2
deployment: RC2
G'day, @Zsolt Szabó
Welcome to the community!
The steps
key under parallel
seems to be misplaced. The steps
keyword should be at the same indentation level as - parallel
, and the list under steps
should contain the individual step
entries. The correct structure should be:
- parallel: steps: - step: <<: *deploy-step-template name: Deploy to Test1 deployment: Test1 - step: <<: *deploy-step-template name: Deploy to Test2 deployment: Test2 - step: <<: *deploy-step-template name: Deploy to RC1 deployment: RC1 - step: <<: *deploy-step-template name: Deploy to RC2 deployment: RC
I hope this helps.
Syahrul
