How can I get / create an environment branch restriction through REST API?
François Collins June 8, 2023
Hi, after creating a deployment environment, how do I set which branch pattern can deploy to it? I see in the doc that I can create environment variables, but no mention of what would show up in the UI as "Branches allowed to deploy to X".
Never mind. I kept searching using different keywords and finally found that it isn't supported: https://jira.atlassian.com/browse/BCLOUD-21703
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
