How can i create a Workspace Webhook?
Keanu Ledger
May 20, 2024 edited
I use a workspace acess_token to make requests to create a workspace webhook, but it fail, and i dont get nothing in terminal. How i kown it fail? I make a request to get all webhooks, but the "value" key comes empty.
Caterina Curti
May 21, 2024
Hi @Keanu Ledger ,
Welcome to our community here.
Can you share a bit more about what you are trying to achieve?
We recently released Forge for Bitbucket and Forge apps can listen to events too. These are the supported events today: https://developer.atlassian.com/platform/forge/events-reference/bitbucket.
If you want to check this option out, I would recommend starting with the following:
- Our getting started tutorial: https://developer.atlassian.com/platform/forge/build-a-hello-world-app-in-bitbucket/
- Or you could jump straight into the https://developer.atlassian.com/platform/forge/automate-bitbucket-using-triggers/ which shows an app that responds to a pull request created events and adds a comment in response to such event.
To answer your exact question, I'm not entirely sure what's happening. I tried a few combinations and I was always either getting an error (e.g. `Your credentials lack one or more required privilege scopes` when the scope wasn't set) or the webhook created. I think the Forge option might be better but if you want to investigate this further please share the payload for the POST and we'll check with that.
Let us know,
Caterina
