How do I Update Lambda Environment Variables using aws-lambda-deploy?
Kyran McCann
August 5, 2022 edited
Edit to add: i updated the pipe version to 1.6.0 and updated path to config file to './stagingconfig.json' and it worked fine.
I'm updating and aliasing. I can't seem to figure out the syntax/order of operations to properly update the environment variables when doing the update.
The variables that I want to use are stored with the bitbucket-pipelines.yml file.
bitbucket-pipelines.yml:
pipelines:
  default:
    - step:
        # Build and package the Lambda function.
        name: Build and package
        script:
          - apt-get update && apt-get install -y zip
          - zip code.zip lambda-name/*
          # Upload the Lambda - make the version number
          #available to subsequent steps via artifacts.
          - pipe: atlassian/aws-lambda-deploy:0.2.1
            variables:
              AWS_ACCESS_KEY_ID: ${AWS_ACCESS_KEY_ID}
              AWS_SECRET_ACCESS_KEY: ${AWS_SECRET_ACCESS_KEY}
              AWS_DEFAULT_REGION: ${AWS_DEFAULT_REGION}
              FUNCTION_NAME: 'lambda-name'
              COMMAND: 'update'
              ZIP_FILE: 'code.zip'
              WAIT: 'true'
        # The pipe exports the newly published
        # Lambda version to a file.
        artifacts:
          - pipe.meta.env
    # You can optionally use AWS Lambda aliases
    # to map the newly published Lambda
    # function version to conceptual environments.
    - step:
        name: Deploy to Staging
        deployment: Staging
        script:
        # Read the 'function_version' from
        # the update pipe into environment variables.
        - source pipe.meta.env
        # Point the 'staging' alias to the function.
          variables:
            AWS_ACCESS_KEY_ID: $AWS_ACCESS_KEY_ID
            AWS_SECRET_ACCESS_KEY: $AWS_SECRET_ACCESS_KEY
            AWS_DEFAULT_REGION: $AWS_DEFAULT_REGION
            SecretName: $SecretName
            FUNCTION_NAME: 'eip-put-rrt'
            COMMAND: 'alias'
            FUNCTION_CONFIGURATION: '~/stagingconfig.json'
            ALIAS: 'dev'
            VERSION: '${function_version}'
stagingconfig.json (in root folder):
    "Environment": {
        "Variables": {
            "Region": "$AWS_DEFAULT_REGION",
            "SecretName": "$SecretName",
            "BucketName": "$BUCKET_NAME"
Igor Stoyanov
August 12, 2022
@Kyran McCann . Thank you for sharing your feedback. It' is always good idea to use latest versions of the pipes, because we provide new features and also maintenance.
Regards, Igor.
