How do I find development mode to enable Sentry with Bitbucket Cloud?
Nick Perkins April 15, 2022 edited
I found this cloud article about enabling `Development mode` on my workspace.
https://support.atlassian.com/bitbucket-cloud/docs/enable-bitbucket-cloud-development-mode/
I go to Settings and there is no option to enable this mode to connect Sentry to Bitbucket.
Has something changed with Jira / Bitbucket that this article is now inaccurate?
[Update 4.15.22 12:26pm EST]
More context.  Was able to add Sentry in the Jira Marketplace, but still see Sentry has Bitbucket not linked.  Jira is good to go though.
seanaty
April 15, 2022
Go to you Workspace settings > "Installed Apps" > Look to the bottom of the page and see "Enable development mode"
@seanaty sadly I can't find a setting in the Workspace settings called `Installed Apps`
seanaty
April 18, 2022
Here is the direct link:
https://bitbucket.org/<your_workspace>/workspace/settings/addon-management
Just replace "<your_workspace>" with your workspace slug.
Nick Perkins April 18, 2022
@seanaty I get this.  I am an admin for the entire jira account. why can't I see this.
Nick Perkins April 20, 2022
@seanaty any ideas here about this not found issue?
seanaty
April 20, 2022
It could be that you're not an admin. Tell me what settings pages are you able to see?
Nick Perkins April 21, 2022
@seanaty I am a Site Admin in Atlassian. I can see the company workspace in bitbucket.
@seanaty is this developer mode a Standard feature in Jira?  That is the plan we have.
Ok getting concerned that this is my problem....oh man
https://jira.atlassian.com/browse/BCLOUD-20342
seanaty
April 25, 2022
It looks to be that issue I'm afraid. All that said, seeing our screenshot reminds me, perhaps you don't need to enable development mode.
Can you try going to Jira under Atlassian integrations and see if you can connect to a Jira instance there?
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
