How do I move a bitbucket repo from one project to another project in the same team
Konstantine Gaspar
November 27, 2018
Seems like an obvious thing to do but I can't see how you do this on the web UI. We have created an Archive project and want to move archived repos to this project, how do I do this?
6 votes
Kurt Klinner
November 27, 2018
@Konstantine Gaspar
  1. Navigate to the repository you want to add to your project.
  2. Click Settings in the sidebar.
  3. Select the project from the Project menu, where you want to move the repository.
  4. Click Save repository details
Konstantine Gaspar
November 29, 2018
Thanks for the prompt answer Kurt, and sorry for the delayed reply :(
I discovered that I didn't have the authority on my teams account to make the changes, which explains why I couldn't figure it out. At least now I can tell my boss how to do it.
Again thanks, much appreciated.
MaturiczIvan October 15, 2020
I have a lot of ptojects, but the UI is bugged, showing only 10 of them in dropdown.
What can I do if the project I need is not in the dropdown?
Like • 2 people like this
RobertSkip_Davis
November 5, 2020
I also see this problem so I can't move my repositories to the project that I need to
darius_v
November 13, 2020
I also created new project but in dropdown I cannot see it :(
Like • Stefan Zhelev likes this
Tash Tan
January 13, 2021
Receiving the same issue, was anyone able to solve this? i.e. i'm also only seeing 10 projects in the dropdown
laouris
January 14, 2021
You are right. The pop up populates ONLY TEN projects.
SOLUTION: start typing inside the project field the name of the project you wish to move your repository to and it will show -;)
Like • 5 people like this
abdelkrim January 31, 2021
The same here, I can only see a limited amount of projects
this is very annoying and certainly if the project you have selected in PUBLIC instead of PRIVATE !!!!
The bug has just been corrected!
jsweeter
March 11, 2021
Still a bug.  I only see 1 of 3 projects.
Savvier Dev
@laourisis the correct answer. Click the drop down, and then start typing the name of the project you want to transfer to, it will start to populate with new results as you type
Like • 4 people like this
Ronald Bolante May 29, 2023
Does this also move the commit history across?  Just wanted to be sure before I do anything drastic.  Thank you.
Developer At Insight
December 13, 2023
Easy to miss, but you can now just change the project field on the repository directly.
Go to:
Repository Settings > Repository Details
and
Select the Project you need from the dropdown
(below the Repository Name field in the centre of the page at the moment).
MiraKopecky
November 26, 2020
This is obviously a bug, was working before with no issues.
v8lust January 7, 2023
A year on and there appears to have been a UI change, previous guidance
Settings now appears to be "Repository Settings". The target project is not available on the selection window, nor can it be found when I type the name?
Spirillen
July 4, 2022
I'm also trying to move a repo from one project to another within the same workspace.
When I do add the new workspace ID "123" and clicking transfer nothing is happening in the destination project for accept transfer.
Nina Barzh
December 27, 2021
Still a problem ...
