I am trying to setup a bitbucket pipeline where the only step i require is the aws codedeploy step.
I have another process that will generate and push the code deploy revision to S3 bucket.
The problem I am facing now is that there is no way to specify the eTag for the generated artifact.
I tried adding the full path of the file (including the eTag) to "VERSION_LABEL" parameter of the aws-code-deploy step but it doesn't work.
Looking at the debug log, the actual AWS CLI call generated on pipeline is this
aws deploy get-application-revision --application-name <APP NAME>> --revision revisionType=S3,s3Location={bucket=<<BUCKET_NAME>>,bundleType=zip,key=<<FILENAME>>?eTag=XXXXXXX} --debug
However, looking at the AWS CLI command line, the eTag should be specified as a key-value.
Apart from running the deploy step manually, is there anyway for me to include eTag in atlassian/aws-code-deploy-0.2.10?
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
