Hello @mahfoudh yosser ,
Workspaces in the Free plan get 50 build minutes per month, with a max of 10 parallel steps running simultaneously. Once you run out of your build minutes, you will not be able to run your pipelines unless you upgrade your plan or wait for the next month's period. However, you also have the option to run your builds in self-hosted runners, where the pipelines will run your scripts in your own infrastructure, and the build minutes will not be charged against your quota.
You can have more details about the pipelines limitations for each of the plans in the documentation below:
Thank you, @mahfoudh yosser .
Patrik S
