How to Resolve PowerShell Invoke-Expression Error When Using Environment Variables in Bitbucket Pipe
Yogesh Kumar August 20, 2024
Hello everyone,
I'm encountering an issue with a Bitbucket pipeline running on a self-hosted Windows runner. I’m trying to use environment variables to execute nuget.exe via PowerShell, but I’m getting an error related to Invoke-Expression.
Invoke-Expression : The expression after '&' in a pipeline element produced an object that was not valid. It must result in a command name, a script block, or a CommandInfo object. At C:\atlassian-bitbucket-pipelines-runner\temp\...\tmp\powershellScript.ps1:11 char:50 + '& $env:NUGET_PATH restore $env:SOLUTION_PATH' | Invoke-Expression + ~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidOperation: (:) [Invoke-Expression], RuntimeException + FullyQualifiedErrorId : BadExpression,Microsoft.PowerShell.Commands.InvokeExpressionCommand
Below is my YAML script:
pipelines:
variables:
 NUGET_PATH: 'C:\Nuget\nuget.exe'
MSBUILD_PATH: 'some path'
MAIN_PROJECT_PATH:'some path'
SOLUTION_PATH : 'some path'
branches:
branch1:
- step:
  name: Building the branch1
runs-on:
- self.hosted
- windows
script:
- "& $env:NUGET_PATH restore $env:SOLUTION_PATH"
I’ve tried different variations, including using backticks and escaping, but I’m still facing the same error. Has anyone encountered this issue or know how to correctly use environment variables in this context? (My syntax in yaml file is coorect when i paste in the question bar so it is not properly formatted)
Any help would be greatly appreciated!
Patrik S
August 22, 2024 edited
Hello @Yogesh Kumar ,
and welcome to the Community!
Checking the YAML file you shared, I can think of two issues that are causing the error :
  1. Variables definitions: I see you defined the variables directly in the YML and that syntax is not actually valid. To define variables to be used in your pipelines, you'll need to create the variables at the workspace, repository or deployment level.
  2. The syntax you have used for the command itself is slightly wrong. The following syntax should work:
    script:
    & "$env:MyCommand" -v
Could you try making those changes and let us know how it goes?
Thank you, @Yogesh Kumar !
Patrik S
Product Admin Site Admin
