Hello Everybody,
I like to setting a specific timezone for Bitbucket cloud product. Is It possible? How to setting the Bitbucket timezone?
Hi, @Rogerio,
I saw that you created a ticket with our support related to the same question, and one of our support engineers has already answered you through that ticket, so I will share their answer here to help other community members that may have the same question.
The way Git works is to create an epoch time, which is automatically generated by each local machine to determine what time it is. Bitbucket simply reads the epoch time and translates it to what time a certain change/commit/pull request happened, so Bitbucket's UI does not control this information, this information comes from Git configuration on the local machine of the user.
With that said, the only way to control this is to check user by user and confirm if their local time and timezone are synchronized with the company standard.
Caroline
Hi @Caroline R , how are you?
Now, I understood. Thank you so much for your support.
Rogerio
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
