I have docker mysql run manually inside pipeline step
How can I simulate that in local ?
Hey @xicond
By local, do you mean running the steps below on your local machine? If yes, please check our KB below, which outlines the steps to reproduce the issue locally in the pipeline. It should be similar to what you wish:
Troubleshoot failed Bitbucket Pipelines locally with Docker
Syahrul
