I have an hg repo on Bitbucket that I need to convert to git. The first step is to clone it to a local machine, but when I run the hg clone command I get the message
"http authorization required for <url>"
Tortoise hg pops a box requesting password, but my current bitbucket pwd does not work.
How to proceed?
No real problem. I just made a new git repo from local data. The old hg repo was made before I started using my current Atlassian login.
Hello @Thomas Sharpless,
Welcome to the Community.
Are you using two-factor authentication or single sign-on by any chance? Your regular credentials won't work for pulling/pushing in that case.
You have two options:
Hope this helps. Let me know if you have any questions.
Daniil
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
