How to cache packages installed from apt-get in bitbucket pipelines?
Drew Gallagher January 12, 2023 edited
I need help caching packages in my bitbucket pipeline that were installed via apt-get.
For non-apt-get installed packages you can find the path where packages are installed online. However, I'm not sure what directorie(s) to cache for apt-get installed packages.
For example I have the following command in my pipeline script:
 - apt-get update && apt-get install -y curl unzip git
I defined a cache directory in definitions like so:
caches:
      apt-cache: /var/cache/apt
However, it's only caching 164 bytes and I don't think it's caching all of the packages that are actually installed.
Is there a way to find where these packages are installed so I can cache them?
Found another answer on the community here https://community.atlassian.com/t5/Bitbucket-questions/Any-way-to-cache-apt-get-install-y-zip-in-bitbucket-pipelines/qaq-p/622876, thanks @Chase Han
Basically you use the following command in your pipeline script or a local docker image that matches the image you have in the pipeline.
which <package-name-here>
e.g
which git
Then it will output a path where it exists.
e.g.
/usr/bin/git
Then you just need to include the path in your cache definitions that contains that package.
e.g.
caches:
      #/usr/bin located packages like git, curl, etc
      usr-bin: /usr/bin
And then you can use that cache definition in your steps
