How to configure Jira Issue transition from Bitbucket Pull Request Merge Screen
Wolfgang Landes June 17, 2020
image.png Within the Merge Screen of Pull Requests in our Bitbucket instance, the possibility of transitioning issues in Jira appeared.
My question is, where I can find documentation on how to configure what the default status for transition is and which workflow is used.
Darcy Sanders
June 17, 2020
Hi, currently it is not possible to configure the default status for the transition. The default status is chosen by selecting the last transition in the list of transitions available for your Jira issue, however this may not always reflect the order of statuses in your workflow. This is a new feature and we're looking for ways to improve its usability.
Leaf (Jessica) Roy
February 3, 2021
There is an issue open for this for Bitbucket Cloud:
https://jira.atlassian.com/browse/BCLOUD-20264
Óscar Mestre May 22, 2024
Thanks for the task, Leaf! Our team will vote on it and we hope it reaches the minimum interest required to be implemented.
