Tried something like
image: php:7-fpm
pipelines:
default:
- step:
script:
- apt-get update && apt-get install -qy git curl libmcrypt-dev mysql-client zip unzip
- yes | pecl install mcrypt-1.0.1
- docker-php-ext-install pdo_mysql
- bash ./install-composer.sh
- composer install
- ln -f -s .env.pipelines .env
- php artisan migrate
- php artisan serve &
- sleep 3
- ./vendor/bin/phpunit
- curl -vk http://localhost:8000
services:
- mysql
definitions:
services:
mysql:
image: mysql:5.7
environment:
MYSQL_DATABASE: 'homestead'
MYSQL_RANDOM_ROOT_PASSWORD: 'yes'
MYSQL_USER: 'homestead'
MYSQL_PASSWORD: 'secret'
or
image: php:7-fpm
pipelines:
default:
- step:
script:
- apt-get update
- apt-get install zip -y
- apt-get install unzip -y
- apt-get install libzip-dev -y
- apt-get install jpegoptim -y
- apt-get install optipng -y
- apt-get install curl -y
- apt-get install mysql-client -y
- docker-php-ext-install zip
- docker-php-ext-install gmp
- docker-php-ext-install bcmath
- curl -sS https://getcomposer.org/installer | php -- --install-dir=/usr/local/bin --filename=composer
- composer install
- php -r "file_exists('.env') || copy('.env.dist', '.env');"
- php artisan key:generate
- php artisan migrate:fresh --seed
- sleep 3
services:
- mysql
definitions:
services:
mysql:
image: mysql:5.7
environment:
all functional tests fail, except unit. unit tests work fine.
Anyone??? I have to create many fake accounts only trying to figure out why it is not working according to docs, because i was running out of free time multiple times.
image: php:7-fpm
pipelines:
default:
- step:
script:
- composer install
- sleep 5
services:
- mysql
definitions:
services:
mysql:
image: mysql:5.7
environment:
#!/bin/bash
COMPOSER_VERSION=${COMPOSER_VERSION:-1.4.2}
curl -s -f -L -o /tmp/installer.php https://raw.githubusercontent.com/composer/getcomposer.org/da290238de6d63faace0343efbdd5aa9354332c5/web/installer \
&& php -r " \
\$signature = '669656bab3166a7aff8a7506b8cb2d1c292f042046c5a994c43155c0be6190fa0355160742ab2e1c88d40d5be660b410'; \
\$hash = hash('SHA384', file_get_contents('/tmp/installer.php')); \
if (!hash_equals(\$signature, \$hash)) { \
unlink('/tmp/installer.php'); \
echo 'Integrity check failed, installer is either corrupt or worse.' . PHP_EOL; \
exit(1); \
&& php /tmp/installer.php --no-ansi --install-dir=/usr/bin --filename=composer --version=${COMPOSER_VERSION} \
&& rm /tmp/installer.php \
&& composer --ansi --version --no-interaction
<?xml version="1.0" encoding="UTF-8"?>
<phpunit backupGlobals="false"
colors="true"
bootstrap="./vendor/autoload.php"
backupStaticAttributes="false"
convertErrorsToExceptions="true"
convertNoticesToExceptions="true"
convertWarningsToExceptions="true"
beStrictAboutTestsThatDoNotTestAnything="true"
beStrictAboutCoversAnnotation="true"
beStrictAboutOutputDuringTests="true"
verbose="true"
beStrictAboutChangesToGlobalState="true"
beStrictAboutTodoAnnotatedTests="true"
stopOnError="false"
stopOnIncomplete="false"
stopOnSkipped="false"
stopOnRisky="false"
processIsolation="true"
stopOnFailure="false">
<testsuites>
<testsuite name="Functional">
<directory suffix="Test.php">./tests/Functional</directory>
</testsuite>
</testsuites>
<filter>
<whitelist processUncoveredFilesFromWhitelist="true">
<directory suffix=".php">./app</directory>
</whitelist>
</filter>
<php>
<env name="APP_ENV" value="testing"/>
<env name="APP_URL" value="localhost"/>
<env name="CACHE_DRIVER" value="array"/>
<env name="SESSION_DRIVER" value="array"/>
<env name="QUEUE_DRIVER" value="sync"/>
</php>
</phpunit>
APP_ENV=local
APP_KEY=ThisIsThe32CharacterKeySecureKey
DB_CONNECTION=mysql
DB_HOST=127.0.0.1
DB_DATABASE=homestead
DB_USERNAME=homestead
DB_PASSWORD=secret
Example test
<?php declare(strict_types=1);
namespace Tests\Functional;
use App\User;
use Illuminate\Foundation\Testing\DatabaseTransactions;
use Tests\TestCase;
final class UrlGetAvailabilityTest extends TestCase{
use DatabaseTransactions;
/** * @dataProvider notAuthenticatedUrls
* @param string $url
* @test
public function WebsiteAvailability_ValidaUrls_SuccessfulResponse(string $url)
$response = $this->get($url);
$this->assertTrue($response->isSuccessful(), "Can not access url {$_SERVER['APP_URL']}/$url");
Used docs
https://confluence.atlassian.com/bitbucket/php-with-bitbucket-pipelines-873907835.html
https://confluence.atlassian.com/bitbucket/laravel-with-bitbucket-pipelines-913473967.html
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
