https://bitbucket.org/re4lfl0w/cuckoo/wiki/Home
I wrote documents in wiki.
I want to export form wiki to PDF.
I don't know away.
Wiki page is only View, History, Edit, Clone wiki, Create wiki...
I searched 'How to convert form wiki to PDF'.
Atlassian answer the way that export to PDF in confluence.
Only way use confluence?
confluence is paid model...
Thanks for watching my question
I've created a Javascript Bookmarklet that remove unnecessary element from DOM and gives you a clean wiki Page that you can print from your browser: https://gist.github.com/markov00/d78ecaa226a8675b70e6
I can't find a one step way that can meet your request. But I find another way that can achieved this goal as well.
There are two ways:
One is to save wiki page as image and use PDF images add-on control to add the content to PDF.
Another way is to copy text and images on wiki and then use PDF editing tool to add the text and images on pdf.
And I'm also looking forward to learn better ways for it.
I have never tried to convert form wiki to PDF on bitbucket. But I wonder whether there are some PDF converter can help with that? How can I select one whose way of processing is simple and fast to help me convert PDF to bmp files or do other pdf to image conversion processing? I also want to check its free trials before the order. Any suggestion will be appreciated. Thanks in advance.
Best regards,
Peter
Hi, according to https://bitbucket.org/site/master/issue/2692/wiki-should-have-a-documentation-like - this feature is not implemented yet. As for workarounds - please see http://stackoverflow.com/questions/10962093/downloading-a-wiki-page-from-bitbucket-as-pdf
