I've noticed that the option to create a Wiki for a repository disappeared from Project Settings - is it no longer possible to create a Wiki for a repository?
G'day, @V
Welcome to the community!
As Yong mentioned above, the link provides an explanation of why you can't create a wiki. In short, wikis are not supported in workspaces managed through admin.atlassian.com. If you setup your workspace via admin.atlassian.com, all wiki features will be disabled.
You can opt-in and try Confluence instead.
Syahrul
I can see Wiki from my BB cloud Standard Plan instance. I think you could take a look at this doc and try to get the answer you're seeking:
https://support.atlassian.com/bitbucket-cloud/docs/use-wikis-to-store-documents/
Good Luck,
Yong
