I am trying to commit (Team - Commit...) my project in Eclipse Version: Mars.2 Release (4.5.2) Build id: 20160218-0600 to Bitbucket and I get the error:
Error occurred computing diffs
C:\Users\Glynd\Documents\gitignore_global.txt (The system cannot find the file specified)
The file is in this location - date last modified 14/01/2020 type .symlink and size 0 KB.
My last commit to Bitbucket was only two days ago.
Does anyone know how to fix this issue please. I am a novice at this so simple step by step instructions would be appreciated.
Hello and welcome to the community!
My guess here would be that the reason for the error is that the file is a symlink.
Eclipse error message mentions that it cannot find the file C:\Users\Glynd\Documents\gitignore_global.txt, which I would assume to be a text file and not a symlink. I am not sure if that was a text file in your working directory and later on it was replaced by a symlink, perhaps accidentally?
If this is the case, you could try a) getting a backup of your local repo first b) delete this file in your working directory and create a new text file with this name and the content you would like it to have, then try committing again.
Theodora
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
