How to leverage Bitbucket deployments dashboard when using AWS Codepipeline/Codebuild for CI-CD
Simran
We have been using AWS Codepipeline/codebuild for CI-CD and use bitbucket cloud for git provider.
After reviewing this wonderful post, https://aws.amazon.com/blogs/devops/aws-codepipeline-build-status-in-a-third-party-git-repository/, I was able to set up feedback from AWS codepipeline in bitbucket.
However, nothing shows up in the Deployments dashboard on Bitbucket cloud still. I would love to be able to see our deployment status on deployments dashboard in bitbucket cloud. Is there a way to achieve that as of now ? Is that in the roadmap?
Caroline R
November 1, 2021
Hi, @Simran
Could you please confirm if you have specified a deployment environment in your YAML file? In case you have, would you be able to double-check whether the deployment name is listed in the Repository Settings > Deployments settings?
In case you would like to read more about how to set up and monitor deployments, you can access the following link:
Please, feel free to share any additional questions regarding this case.
Caroline
Simran
@Caroline R  Thanks for your response. In the link you shared, it says:
 Add the deployment keyword, followed by the name of the environment, into the relevant step in your bitbucket-pipelines.yml file.
I do not have a bitbucket-pipelines.yml file because we are using code pipeline/code build for CI-CD. Based on https://aws.amazon.com/blogs/devops/aws-codepipeline-build-status-in-a-third-party-git-repository/, have been able to have pipeline status posted back to bitbucket from AWS code pipeline, would like to understand how to expand that solution so that it shows up in the deployments as well.
Like Steffen Opel _Utoolity_ likes this
Caroline R
November 1, 2021
Hi, @Simran
Thanks for the additional information. In this case, there is no native way to achieve that, however, you can use the following Pipe to see the deployments:
I hope this helps, but do let me know if you have any questions.
Caroline
Simran
@Caroline R Thanks for your response. We are not using codedeploy but codepipeline and codbeuild. Since it's possible to share the pipeline feedback with bucket as documented here, https://aws.amazon.com/blogs/devops/aws-codepipeline-build-status-in-a-third-party-git-repository/  , my understanding is that deployments should be similar as well. Would be great if you could please have this looked into internally? I'll check with AWS support as well. Thanks
Like 2 people like this
Caroline R
November 2, 2021
Hi, @Simran
I brought this matter to the developers and they confirmed that Deployments are only available from Pipelines (not available from the Bitbucket Cloud and Codebuild integration). They suggested that you give a try to Bitbucket Pipelines as it’s supported out-of-the-box and provides Deployments support or nice integrations with other Atlassian tools such as Jira, JSM, etc.
As you mentioned you would check with AWS support, I would recommend asking them if it's possible to create a feature request on their side to implement that.
Caroline
Jeffrey Bistrong
February 17, 2022
@Simran curious if you found a solution for this as I am interested in doing the same thing since we use AWS for CI/CD as well.
Simran
@Jeffrey Bistrong  No solution for JIRA dashboard, Just planning to use Serverless dashboard for the version tracking. Not what I wanted to do, but seems like the way forward for now.
Andy Mell
September 1, 2023
Has the bitbucket API endpoint been added yet for us to report deployments from external CI/CD such as codepipeline?
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
