How to migrate from bitbucket to stash
David Kunkel February 19, 2013
We are currently using BitBucket and want to move our repositories to Stash.
5 votes
Alexey_Efimov
February 20, 2013
It documented on Atlassian Docs:
https://confluence.atlassian.com/display/STASH/Importing+code+from+an+existing+project#Importingcodefromanexistingproject-MirroranexistingGitrepository
It is significat to make Bare clone, not simple Copy clone. Because if you make not a Bare mirror, you get no remote branches. And push --all will not work fine.
I used follow commands to completelly migrate from one Git to another, this will copy anything:
git clone --bare git@bitbucket.org:/login/myrepo.git
cd myrepo.git
git push --mirror git@stash.acme.com:/project/myrepo.git
cd ..
rm -rf myrepo.git
In this solution you no need to add remote.
cofarrell
February 20, 2013
Thanks Alexey. You're quite right - that's actually a better way to do it.
AndyM April 17, 2013
Wouldn't it be better to mirror the clone at the first step?
git clone --mirror git@bitbucket.org:/login/myrepo.git
Also, is the process repeatable if commits are made to the Bitbucket repo?
Dharmendra Verma
May 30, 2013
Here is a python script to do this for you.
https://github.com/dkvermavit/git-server-backup-script
cofarrell
February 19, 2013
Hi David,
I guess this depends on how many repositories you have to migrate? If we're talking 5-10, then frankly I would just do it manually for now.
If you have more thant that it might be worth thinking about writing a script (which we could definitely help with). You could use both the REST endpoints to query the Bitbucket repositories and re-create them in Stash.
Charles
cofarrell
February 20, 2013
Not specifically. It's really just the normal Stash documentation you might want to take a look at:
https://confluence.atlassian.com/display/STASH/Stash+Documentation+Home
For each repository in Bitbucket you will want to clone the repository to a machine, create a matching repository in Stash and then push all the branches/tags. Something like:
git clone git@bitbucket.org:project/repo-name.git
cd repo-name
git remote add stash ssh://git@server:7999/PROJECT/repo-name.git git push --all stash && git push --tags stash
You may then also want/need to setup user permissions on your projects as appropriate to your organization.
I hope this helps?
Charles
David Kunkel February 20, 2013
Hi Charles,
Is there some documentation somewhere on how to do this manually?
Dave
David Kunkel February 24, 2013
Thanks for everyone's help - I'll get started with the migration today.
Dave Kunkel
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
