How can i pass some flags to a script using script mode with ssh-run?
- step:
script:
- pipe: atlassian/ssh-run:0.4.0
variables:
SSH_USER: ...some_users...
SERVER: ...some_ip...
MODE: 'script'
COMMAND: 'test.sh'
Hi @Emptyfruit
Thank you for contacting Atlassian Community. My name is Norbert and I'm a Bitbucket Cloud Support Engineer, it's nice to meet you!
I'd like to inform you that unfortunately it's not possible to pass flags to a script, once you run it in a script mode. In case you wish to run a script and passing a flag, I'd like to recommend you to copy the script to the server and switch to "command" mode instead of "script"
Please let us know if you have any further question?
Best Regards,
Norbert
Atlassian Bitbucket Cloud Support
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
