I tried multiple ways to do this but none worked for me. In the end, I ended up with the following step:
script:
- gradle build -x check
- wget https://github.com/snyk/snyk/releases/download/v1.464.0/snyk-linux
- chmod +x snyk-linux
- ./snyk-linux auth $SNYK_TOKEN
- ./snyk-linux test -d --all-projects --json-file-output=snyk-test-output.json
- cat snyk-test-output.json
- pipe: snyk/snyk-scan:0.4.6
variables:
SNYK_TOKEN: $SNYK_TOKEN
SNYK_TEST_JSON_INPUT: "snyk-test-output.json"
This, however, results in an error:
===== DEBUG INFORMATION START =====
gradle command: '/opt/atlassian/pipelines/agent/build/gradlew' snykResolvedDepsJson -q --build-file build.gradle --no-daemon -Dorg.gradle.parallel= -Dorg.gradle.console=plain -I /tmp/tmp-202-8XBM7uGB0V1d--init.gradle
[COULD NOT RUN gradle -v]
>>> exit code: 126
>>> stdout:
>>> stderr:
/bin/sh: 1: /opt/atlassian/pipelines/agent/build/gradlew: Permission denied
===== DEBUG INFORMATION END =====
When I run the same sequence of commands, all works fine:
This is the link to my project: https://bitbucket.org/ig0rski/spring-boot-example/src/master/
Solved it. There were two problems. The first was that the wrapper was not executable. The second was that the wrapper was not set up properly (more info here: https://support.snyk.io/hc/en-us/articles/360007745957-Snyk-test-Could-not-find-or-load-main-class-org-gradle-wrapper-GradleWrapperMain).
The step configuration in the end is:
- step:
script:
- wget https://github.com/snyk/snyk/releases/download/v1.466.0/snyk-linux
- chmod +x gradlew
- gradle wrapper --gradle-version 6.8.3 --distribution-type all
variables:
Hi @Igorski ,
I've tried a similar solution as the one you've posted, for a Gradle project, but with some variations:
- step:
name: 'Deployment to Staging'
deployment: staging
script:
- ./gradlew build -x check
- nvm install 10.24.1
- npm -g config set user root
- npm install -g snyk
- snyk auth $SNYK_TOKEN
- snyk test --all-sub-projects --severity-threshold=high --json-file-output=snyk-test-output.json
after-script:
variables:
In this case, the installation of Snyk CLI has been done via npm. And the other variation is that the Snyk is in the "after-script" section. When I've tried the Snyk pipe after the last snyk command, if the test found a vulnerability, the build stopped and the Sny pipe was not executed. So the report was not shown. But if the test has not found a vulnerability, the report was shown.
It was only when the Snky was configured in the "after-script" that the report is shown in both scenarios, when the test passes without vulnerabilities or when a vulnerability is found.
Have you seen this behaviour too? If not, what do you think is wrong in my apporach?
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
