How to run a custom pipeline on all self.hosted runners
DARSHAN GAD February 6, 2025 edited
I need to perform certain actions on all the self.hosted runners. like a maintenance work.
Right now, these custom pipelines with the intended actions are only executed randomly on the runners available at the scheduled time.
Is there a way I can force this pipeline to run on all available runners?
Syahrul
February 9, 2025
G'day, @DARSHAN GAD
Welcome to the community!
Please correct me if I'm mistaken, but are you considering running all available runners for maintenance tasks simultaneously? If so, you might consider executing a build with parallel steps using the "all runners" flag. This approach will utilize all available runners, allowing idle runners to be used when others are busy, thus enabling concurrent execution.
Regards
syahrul
DARSHAN GAD March 10, 2025
Hello @Syahrul
Yes you have interpreted the question exactly as it was meant. I want to run some maintenance task on all runners.
I will try the "all runners" flag see if it works for my use-case.
Thank you for the tips.
Darshan
