How to run the same pipeline steps on master and pull-requests only
Aaron Bauman
Scenario:
I have a ~10 line pipeline step that I want to define once and run against every commit to master, every time a PR is created, and every commit to a branch with an open PR.
How can I define a pipelines config to do this, with as little repetition as possible? I'd like to avoid re-defining the exact same step 2 or 3 times.
Daniel Santos
September 11, 2019
Hi @Aaron Bauman
I hope that this example can help you to reproduce the configuration:
definitions:
  step: &myCommonStep
    script:
      - echo "command 1"
      - echo "command 2"
pipelines:
  pull-requests:
         - step: *myCommonStep
  branches:
    master:
  default:
     - step:
        script:
          - echo "command 3"
          - echo "command 4"
In the example above the step myCommonStep will only run for pull requests and the master branch (running commands 1 and 2). All other commits coming to different branches will trigger the default section which will run command 3 and 4 only.
Let me know if you have more questions about this.
