How to set up a Wiki and an Issue Tracker
eiger3970
Hi, I tried to setup a Wiki and the instructions are not corresponding to what my Bitbucket repository shows.
1. Navigate to your bb101repo. (I have no bb101repo), only a repo I setup as I didn't need to go through the 60 minute walkthrough.
How to setup a Wiki for users already with a repository?
I create a Wiki and save the details and then all that work I typed up has disappeared and isn't showing in the Wiki History.
Mirek
April 14, 2014
Hi eiger3970,
I think you don't need to have a bb101repo. This is only an example of the name. Just navigate to the seetings of your repository and follow the instructions in the documentation:
https://confluence.atlassian.com/display/BITBUCKET/Set+up+a+Wiki+and+an+Issue+Tracker
Instead of bb101repo use name of your repository.
Or if above documentation is confusing for you.. then you can use below:
https://confluence.atlassian.com/display/BITBUCKET/Enable+an+issue+tracker
https://confluence.atlassian.com/display/BITBUCKET/Enable+a+Wiki
I hope that will help.
Best Regards,
Mirek
