asked on Twitter to @Bitbucket
Prateek,
Thanks for the question. The problem here is that we do not want to expose the e-mail address of users. We require them to either sign-up or just use an anonymous ticket (essentially, we don't want to be a messageboard)
Take for example a busy public issue tracker such as TortoiseHg: https://bitbucket.org/tortoisehg/thg/issues/?kind=bug&status=open
Users can signup and create issues on the tracker and you can receive these messages via our internal mail app (or e-mail, if you're watching this issue tracker)
Jesse
However, if you're willing to spend a small amount each month, I'd recommend JIRA Service Desk: https://www.atlassian.com/software/jira/service-desk
It's a lot more robust than Bitbucket's issue tracker, and only $10 a month* for 1-3 agents and unlimited customers. Might be worth checking out!
*I think this requires a regular JIRA license as well
Jesse
Hi - I am the OP.
My use case is as follows - I am the sole developer for a small web app where the code is hosted on bitbucket. As part of the UI, I have a "Report Issue" link. End-users who are facing problems can click the link and they are redirected to the bitbucket issue tracker where they post their issue.
Unfortunately, since these users do not have bitbucket accounts, the issue tracker must be kept anonymous. The side-effect of this is that there is no way for me to track who reported what issue and I cannot contact them for clarifications or once I have fixed the issue.
I need a way to track who reported each issue given that they are not bitbucket users. An easy way would be to pass some identification information in the GET request to /issues/new as a query parameter but I don't think this is allowed.
I could use the Issue API and create my own UI to submit issues and then put the user metadata into one of the allowed fields but this is:
a) Overkill for my app
b) Ugly as heck and probably not intended by Atlassian
So I don't want to do that unless I have no other choice.
