is it possible to enable experimental features in Docker, in order to use `docker buildx` for cross compilation?
This is what I am looking forward to running.
- DOCKER_CLI_EXPERIMENTAL=enabled docker buildx build --platform linux/arm/v7 -t my-image:my-tag --push .
2023 now and still no support
I don't think this is possible using the Bitbucket Cloud Docker daemon. It seems Bitbucket Cloud is still using an 'old' version of Docker (19.03.15) which does not support the buildx plugin yet. I think we should push Atlassian to start supporting this.
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
