How to use environment variable as path in artifact
Zackky Muhammad
October 15, 2018
I need to use env variable as path in artifacts, so path can be more configurable.
my pipelines is like this:
- step:
name: Install and build
caches:
- yarn #cache is defined below in the definitions section
script:
- cd $FRONTEND_PATH
- yarn install
- yarn build
artifacts:
- $FRONTEND_PATH/build/**
but this doesn't work.
Deleted user January 4, 2019
I'm running into this issue as well. Were you able to find a solution, @Zackky Muhammad?
Luke Siedle
February 13, 2020
I wasn't able to solve this with a var, but knowing that your path is probably unique helps, for example
Can become:
- **/build/**
 If you can be even more specific with your path you could rule out creating unnecessary artifacts.
